Old 30-Oct-2010, 1:56 AM   #9
No static at all
No static at all's Avatar
Jim, Tigerbangs is correct. Getting something outside will likely be your best bet at this point. I'm was hoping the trap would help somewhat since channel 11 is working for you. I've tried attic antennas here before, but both 11 & 13 were a bust even with much stronger signals. The antenna actually worked better just sitting on the ground than it did in the attic.
One other remote possibility worth investigating may be some type of RF interference near the TV or antenna. (computer, soundbar, etc . . ) A powered speaker system on my TV completely wiped out a weak VHF 12, even with an outdoor antenna on the other end of the house.
