Any guidance on the HD Stacker Antenna from Denny's?
Well, he's never provided any useful performance data on the antenna (even when pressed), I've never tested it (don't plan to, either), you have no need for its low-VHF elements which contribute to its size and bulk, and I'd suspect that the Siamese twin concept has ill-considered side effects in terms of undesirable coupling between the two antenna sections.
The C4 and other UHF-only antennas shouldn't be particularly susceptible to FM interference. In any event, that issue is easily handled with FM traps/filters in most circumstances.
Our PA18 would certainly be recommended for this application should a pre-amp be required.
