Old 9-Jul-2013, 9:00 PM   #6
To keep it Simple.
If you like you can install 1 antenna , HD7696P antenna or HD7697P antenna aimed at about 45 degree magnetic compass direction.
KQSA has The Country Network on channel 12 in the direction of 320 degree magnetic compass direction , the signal strength is Very Weak.
KQSA is the main reason for the the 2 antenna set up , other then that the Networks are the same NBC , FOX , ABC , CW , PBS , MyNetwork , same Networks , both directions , the local programing and ads, will be different.
_____
Makes no difference the antenna that is on top or bottom.
I think it looks better to have the Y10-7-13 on the bottom and the CS4 on the top , however either way is Ok.
