Old 9-Jul-2013, 6:46 PM   #3
The Broadcast Tv station Are Weak Signal Strength at your location.
Ok , here is how to receive both groups of Broadcast Tv stations/channels , the North West group , and the , North East Group , at the same time with 2 antennas , one preamp , one down lead , and a non power passing 8 way splitter.
Above the Peak Of The Roof in such a manner that reception is not impeded and blocked by the roof and house in the directions of , North West , North East.
Install a AntennasDirect , Clear Stream 4 UHF antenna with the ->Reflector Screens Removed.
This will allow the CS4 to receive at the front and back of the CS4 antenna.
Aim the CS4 antenna at about 85 degree magnetic compass direction , this will position the CS4 to receive the 2 groups of Tv stations at the front and back of the CS4 antenna.
Adjust the aim direction of the CS4 antenna for best reception of the 2 groups of Tv stations directions.
Also install a AntennaCraft , Y10-7-13 VHF high band antenna aimed at about 320 degree magnetic compass direction.
___
___
The CS4 and Y10-7-13 antennas Must Be Up In The Air Clear of Obstructions to reception by the roof and house.
___
The CS4 and Y10-7-13 antennas are connected together with a UHF/VHF diplexer/combiner. AntennasDirect , Model Number , EU385CF-1s .
___
Install a Channel Master CM7777 preamp to the output of the UHF/VHF combiner so that both antennas are amplified at the same time.
___
The , preamp unit , power injector , power supply , are all connected , before the input of a , Non power passing , 8 way passive splitter.
So power supply and power injector is going to the preamp unit only.
A Non power passing splitter is used , so as to not pass the preamp power out to Tv locations.
If 6 Tv's are connected , then use a 6 way Non power passing passive splitter.
___________________
Use the 5 foot tripod antenna mount , ronard (911).
Use the , ronard (4560) , eave antenna mount.
Measure the chimney and use a , ronard (2212) , ronard (2218) , ronard (2224) .
Buy the ronard antenna mounts at solidsignal by typing , ronard (x) , in the solisignal search box or buy from ronard.
_______________
Here are some places to buy antennas and ect. .
http://www.solidsignal.com.
http://www.amazon.com.
http://www.antennacraft.net.
http://www.antennasdirect.com.
___________________________________________
Last edited by teleview; 9-Jul-2013 at 10:48 PM. Reason: Clarify information and typos.
