Old 9-Jul-2013, 11:41 AM   #2
WKTV-DT Real UHF Digital channel 29 is Very Weak Signal Strength , Will Not be received with a attic antenna.
Reception of ALL the USA Digital Broadcast Tv stations/channels can happen with 1 antenna.
Above the Peak Of The Roof in such a manner that the roof and house are not impeding and blocking reception to the , South East , South West , West.
Install a Winegard HD9095P UHF antenna aimed at 166 degree magnetic compass direction. WKTV NBC.
The HD9095P UHF antenna will do better at receiving at the front angle and back angle of the HD9095P antenna , (then the DB8) , the Strong Signal Strengths of ,
WPBS UHF channel 41 PBS.
WWTI UHF channel 21 ABC and CW.
WNYF UHF channel 35 FOX and CBS.
And even WWNY VHF channel 07 because channel 07 is ->Very strong Signal Strength.
______________________________________
If you will also like to receive , CKWS-DT VHF channel 11 , CBC.
WWNY VHF channel 07 is a Very Strong Signal and CKWS VHF channel 11 is a Very Weak Signal Strength.
As a compromise of a small VHF antenna with low gain or a big VHF antenna with high gain.
Install a , Antennas Direct - C5 antenna aimed at about 300 degree magnetic compass direction.
The C5 is Also installed Above The Roof.
Put the C5 antenna above the HD9095P antenna and separate by about 2 feet on the same mast.
The C5 comes with a VHF/UHF , diplexer/combiner.
Connect the VHF connection of the combiner to the C5 antenna.
Connect the UHF connection of the combiner to the HD9095P antenna.
The remaining connection of the combiner connects via coax to the Tv.
___
Try reception Without a antenna system amplifier.
If a antenna system amplifier is required for reliable reception of the Weak Signal Strength , WKTV NBC and CKWS CBC.
Then try a Winegard LNA-100 'Boost' amplifier.
The LNA-100 has high resistance to over load from the local strong signal strength Tv stations.
I strongly recommend New coax and connections outside.
To keep Weather/Water out of outside connections.
Use the coax that has the Compression type connectors on the ends of the coax , not the old crimp type connectors.
Strongly recommend new connections outside.
To make double sure , Weather/Water does not get into connections outside , wrap with http://www.coaxseal..
I recommend Remove and Discard , Rubber Weather Boots , rubber weather boots take in water and hold the water inside the boot , not good for connections.
The C5 is a Very Strong And Durable antenna that will last a long time outside.
The HD9095P antenna is a Very Strong And Durable antenna that will last a long time outside.
http://www.solidsignal.com.
http://www.amazon.com.
http://www.antennasdirect.com.
http://www.winegardirect.com.
Last edited by teleview; 15-Jul-2013 at 7:42 AM. Reason: Clarify information and typos.
