Old 8-Jul-2013, 7:31 PM   #1
rvn
Antenna advice...
Hello,
I'm looking to see what my options are for improved reception.
First, a current TVFool link:
http://www.tvfool.com/?option=com_wr...0559fc4abccb69
Currently we get the green channels (sometimes spotty reception, depending on weather), with this less expensive antenna, Philips SDV5122T/27
http://www.p4c.philips.com/cgi-bin/d...tn=SDV5122T/27 It sits right next to the TV.
Even that had spottier reception until I used a beefier cable, versus the one that came with it. So, it's right on the edge and sometimes we have to fiddle with the antenna. I can see the "green" towers, although there are some tall trees, etc. In general, it's OK, but the reception does drop out enough so that it's pretty annoying, at least to my wife :-)
What I'd really like to do is pull in NBC which is 67.5 miles away, and listed as red, in addition to the others "greens" I currently get.
I was thinking I might be able to get a DB8 and mount that in my attic, pointed at the tower 67.5 miles away, and, if necessary (will it definitely be necessary?), couple it with a ClearStream 5 (or even my current antenna?) for the VHF channels, that I currently get. Both in the attic...
I do have a tripod/mast on my roof, which I could put the DB8 on, but would prefer the indoor setup, to avoid the wear/tear, lightning threat, etc... but if I have to get up it up there, I can and will...
Is my only way to know just to get the DB8 kit with a preamp, and run it right into the TV to see what kind of reception I get? My roof would make the antenna about 25-30 feet up, and there are a few trees, etc...
Any help would be greatly appreciated. This is a wonderful site! I have been reading for hours and days...
Thank you!
Jon
rvn is offline   Reply With Quote
