Old 8-Jul-2013, 4:55 PM   #2
Attics and the inside of buildings Are Not a reception environment and Never Will Be a reception friendly environment.
Multi-path reflections signals bouncing all around , absorbing , blocking , Broadcast Tv reception.
Install a ANT751 antenna in the attic aimed at about 112 degree magnetic compass direction.
____________
A antenna system amplifier is not required.
____________
For 3 Tv's connected use a simple common 3 way splitter.
____________
If reception issues happen that are not resolvable with antenna aim and location in the attic.
Move the ANT751 antenna to above the Peak Of The Roof in such a manner that reception is not impeded or blocked by the roof and building in All directions.
Above the roof , aim the ANT751 at about 112 degree magnetic compass direction.
________________________
