Old 3-Jul-2013, 10:06 PM   #13
mulliganman
Originally Posted by teleview View Post
Buy the HFS splitters at , http://www.solidsignal.com or http://www.hollandelectronics.com.
Does it matter on the cable I get? I have been looking at cables from both Antennas Direct and Solid Signal. Or do I need cables at all if a satellite is already installed on the rooftop?
Also, if the Clearstream 2V setup with the preamp as you suggested doesn't work and I have to go to a 2 antenna setup how would the setup change and what should be paired with the CS2V? The CS2?
I was able to locate the Antennas Direct CPA 19 preamp on the Best Buy website and have it ordered and is on its way.
