Old 28-Oct-2010, 7:23 PM   #3
At best, expect to receive four stations, if you are willing to install a large UHF/VHF combination such as the CM3761B http://salestores.com/chma36ulcrse.html
A rotor will be needed.
A high quality preamplifier will be needed. For example, http://www.antennasdirect.com/store/...e_amp_kit.html
The higher the antenna can be mounted the better.
Here a some threads re. installers: http://forum.tvfool.com/forumdisplay.php?f=8
A well qualified installer will have local knowledge and be equipped to put a test antenna in the air so that you can know what to expect from the completed install.
Last edited by GroundUrMast; 28-Oct-2010 at 7:36 PM. Reason: considering updated report
