Old 3-Jul-2013, 1:22 PM   #4
Originally Posted by NickelBach View Post
Sorry, the room faces WEST, not east.
Which is likely the reason that you were only able to pick up a few stations. Most likely, the bulk of the signals are getting blocked by construction materials and other ground clutter.
Best results are obtained by optimal antenna placement. Getting the antenna to a spot where the signals can cleanly get to the antenna will work wonders for reception. Placing the correct antenna in a signal-lousy location usually yields lousy results.
A small roof or attic mounted 7-51 antenna should get your the DC stations.
