Old 2-Jul-2013, 8:10 PM   #2
Based on the tvfool report being resolved to the block level only , and the default 10 feet antenna height above ground.
Above the Peak Of The Roof in such a manner that the roof and house do not impede or block reception to the , north east , south west.
Install and aim a Winegard HD7698P antenna at about 76 degree magnetic compass direction , north east.
WWTO channel 10 to the south west , is strong signal strength and will be received through the back angle of the HD7698P antenna.
So only 1 HD7698P antenna is required for reception.
Here are some strong and sturdy above the roof antenna mounts.
http://www.ronard.com/909911.html. Use the 5 foot , ronard (911) , tripod antenna mount.
http://www.ronard.com/34424560.html. Use the , ronard (4560) , eave antenna mount.
http://www.ronard.com/ychim.html. Measure the chimney and use. ronard (2212) , or , ronard (2218) , or , ronard (2224) .
Buy the ronard antenna mounts at solidsignal by typing , ronard (x) in the the solidsignal search box or buy from ronard.
Here are some places to by antennas and etc. .
http://www.solidsignal.com.
http://www.amazon.com.
______________
Install a Winegard HDP-269 preamp.
______________
For 1 tv connected use No splitter.
For 3 Tv's connected use a HFS-3D , 3 way splitter.
Buy the HFS splitters at , http://www.solidsignal.com or http://www.hollandelectronics.com.
______________________________________
Disconnect and Remove All passive and active satellite system componets such as and not limited to , multi-switches , multi-plexers , combiners , splitters , amplifiers , power injectors , powers supplies and etc. .
Yes the satellite system coaxes and other coaxes can be used for the Broadcast Tv antenna system.
Last edited by teleview; 4-Jul-2013 at 7:58 AM. Reason: Clarify information and typos.
