Old 1-Jul-2013, 9:36 AM   #2
A Simple reception.
The Current Broadcast Tv stations/channels transmitted and received in the , USA , Canada , Mexico , are.
UHF band channels 14 thru 51.
Your location has receivable Broadcast Tv stations/channels in All 3 Tv bands.
________________________________
Above the Peak of The Roof in such a manner that the reception is not bolcked by the roof and house in the direction of , south east.
Install a Winegard HD7084P ALL Channel Antenna aimed at about 120 degree magnetic compass direction.
___________
http://www.ronard.com/909911.html. Use the 5 foot , ronard (911) , antenna mount.
http://www.ronard.com/34424560.html. Use the , ronard (4560) , eave antenna mount.
http://www.ronard.com/ychim.html. Measure the chimney and install a , ronard (2212) or ronard (2218) or ronard (2224) , chimney antenna mount.
Buy the ronard antenna mounts at soildsignal by typing , ronard (x) , in the soildsignal search box or buy from ronard.
________________________________________________________
Install a Winegard , LNA-100 'Boost' , antenna system amplifier.
http://www.solidsignal.com.
http://www.amazon.com.
http://www.winegardirect.com.
http://www.ronard.com.
As always , trees and tree leaves , plants and plant leaves , have a Negative effect on Broadcast Tv reception and so do buildings including your own roof and house and other obstructions.
The Best Practice is to install a Tv reception antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own roof and house.
Last edited by teleview; 1-Jul-2013 at 5:45 PM. Reason: Clarify information and typos.
