Old 28-Jun-2013, 10:10 AM   #4
Receive Broadcast Tv with a Tv antenna.
The Current Broadcast Tv Channels in the , USA , Canada , Mexico , are.
UHF band channels 14 thru 51.
________________________________
Your location has Receivable channels in All 3 Tv Bands.
Many of the Receivable Tv stations/channels are weak signal strength.
I recommend a Large All Channel Antenna , a Winegard HD7084P antenna.
__________________________________________________________________
A Learning Experience is install a Winegard HD7084P ALL channel antenna in the attic.
In the attic , aim the HD7084P ALL channel antenna at about 96 degree magnetic compass direction.
Install a Winegard LNA-100 'Boost' amplifier.
For 3 Tv's connected use a simple common 3 way splitter.
http://www.solidsignal.com.
http://www.amazon.com.
If some Tv stations/channels are not received reliably with the HD7084P antenna in the attic , try adjusting the aim direction and location of the HD7084P antenna in the attic.
If the attic reception is still not reliable.
Move and install the HD7084P ALL channel antenna Above The Roof in such a manner that the roof and and house are not blocking reception to the east at about 96 degree magnetic compass direction.
With the HD7084P ALL channel antenna above the roof , Test reception , without and with the LNA-100 amplifier.
http://www.ronard.com/34424560.html. Use the , ronard (4560) , eave antenna mount.
Measure the chimney , and select a ronard chimney antenna mount.
http://www.ronard.com/ychim.html. ronard (2212) , ronard (2218) , ronard (2224) .
Buy the , ronard (xxxx) , antenna mount at solidsignal or buy from ronard.
http://www.ronard.com.
Last edited by teleview; 30-Jun-2013 at 3:42 AM. Reason: Clarify information and typos.
