As a Test to prove reception , one way or the other.
Install the HD7000R antenna Above The Peak Of The Roof in such a manner that there is the least amount to no amount of obstructions of any type or kind in the directions of reception including your own roof and house.
Connect a New matching transformer (balun) to the HD7000R antenna.
Connect a New continues length of coax to the New matching transformer.
Make the New continues length of coax 70 feet long.
Run the New continues length of coax through a open door or window , Direct to 1 Tv.
To test reception , aim the HD7000R antenna at about 311 degree magnetic compass direction and about 18 degree magnetic compass direction.
And can also aim the HD7000R antenna at about 73 degree magnetic compass direction.
_________________________________________
Your Tvfool report is showing Strong Signal Strength Tv stations/channels that are LOS=Line Of Sight reception.
KQEH Real UHF Digital channel 50 is , 40.1 NM(dB) in the green reception zone and is only 20.8 miles away and is LOS=Line Of Sight.
The Tv stations that have 1 and 2 Edge path obstructions are Strong Signal Strength and are very close to your location.
___________________
What direction is the "higher house" from your location?? , and what is the distance to the higher house??
What are the directions of the trees?? , and what is the distance to the trees??
Reason: Clarify information and typos.
