Just cut the cord this weekend on the cable.
Purchased a cheap pancake type antenna and installed in the attic just to see how things worked. Of course it worked great - plug and play.
Now I need to try and get setup for the football season in the fall, and the US stations. My plan is to return the antenna I have now and replace with something else installed on the roof.
In the earlier post you suggested a CM-4228, I was wondering if there was an advantage going with something like a CM-3671 (or a CM-3679 a little more reasonable size) it is a monster but I have a good solid chimmney to mount it to so I would be able to do that if it gives me a better chance of the distant stations.
You had mentioned that with the CM-4228 I would probably still get all local with the antenna pointed toward US - is that correct for a CM-3671 type antennas as well?
Thanks,
