Old 23-Jun-2013, 2:33 PM   #1
strhow
Need general signal capture help
Hi all, hopefully I've included enough information to help diagnose my problem. I'm looking for a little help bringing in more OTA stations to my TV. I'm currently using a Winegard Flatwave and have tried it at two particular angles with differing results.
Before I go on too long, here are my signal analysis results(I'm including some old results because the new results aren't showing on the page for some reason):
15ft AGL:
http://www.tvfool.com/?option=com_wr...1dda5ceb3184e0
25ft AGL:
http://www.tvfool.com/?option=com_wr...1dda853717ab7c
25ft AGL:
http://www.tvfool.com/?option=com_wr...0559f949f7f8e2
I am most interested in channels 3,9,12,18,53,61.
With the flatwave pointed at 0 degrees mag N I can currently get 3,9,18,23,30(3AB-analog)
With the flatwave pointed at 349 degrees mag N I can currently get 3,12,18,30(3AB-analog)
I don't even see channel 30 in the charts but there it is on the TV.
I would like to keep the antenna inside and avoid an exterior mounting, it is rental property. But I own it and could exterior mount if required. One complicating factor is that there is a row of trees (not very deep) towering over the house to the north & north west and ~20' from the antenna.
What will I need to do to accomplish my goals or how can I incrementally test to see if my goals are able to be accomplished ?
ps. If it matters, I am currently running dedicated coax for the tv but would like to move over to the same coax I'm running my MOCA network on at 1500MHz.
strhow is offline   Reply With Quote
