Old 28-Oct-2010, 5:51 AM   #2
You must be on a high spot, I envy you just a bit. You may want to try basic 'rabbit ears' http://www.solidsignal.com/pview.asp...u=020572040105
That should provide coverage of most of the station in the green section of your report.
No complicated install.
If you choose a larger directional antenna, you will add a few channels but need to add a rotor.
