Wow, fantastic reply! Thank you so much. I was eyeing the ANT751, as it is a smaller unit and one I could "borrow" from a local store and return if it didn't work out. Others would require shipping, etc. I hadn't even thought of the online streaming options. I'll check it all out, as that would add an extra dimension to the OTA channels. I already use a computer to record shows off the antenna, so it would be easy to pull in Hulu or the like.
Will let you know how it all turns out, or if I run into any snags. Thanks again.
