Old 14-Jun-2013, 11:05 PM   #2
Antenna recommendations and More.
For the reception of Some Digital Broadcast Tv stations/channels.
Install a TERK HDTVa indoor antenna at the Tv location , and adjust the TERK HDTVa antenna for best reception.
________________________________________
For reception of More Digital Broadcast Tv stations/channels , put the TERK HDTVa antenna in a , east , north east , facing window.
And aim the TERK HDTVa antenna at about , 70 degree magnetic compass direction.
Here is how to aim indoor and outdoor antennas , http://www.kyes.com/antenna/pointing/pointing.html.
_________________________________________
To receive More Digital Broadcast Tv stations/channels.
Install a Channel Master CM4228HD UHF/VHF antenna in the attic.
Aim the CM4228HD antenna at about 70 degree magnetic compass direction.
_____________________________________________________________________________
Inside of buildings and attics Are Not a reception friendly environment and Never Will Be a reception friendly environment
Multi-path reflections , absorbing , blocking , Broadcast Tv Reception.
______________________________________________________________________________
To improve the Quality/Stability of Reception and Receive More Digital Broadcast Tv stations/channels.
Install the CM4228HD antenna Above the Peak of the Roof in such a manner roof and house are not blocking reception to the , east north east , south east , south west.
Aim the CM4228HD antenna at about , 70 degree magnetic compass direction.
Here is how to aim outdoor and indoor antennas , http://www.kyes.com/antennas/pointing/pointing.html.
______________
http://www.ronard.com/909911.html. Use the , ronard (911) , 5 foot tripod antenna mount.
http://www.ronard.com/34424560.html. Use the , ronard (4560) , eave antenna mount.
http://www.ronard.com/ychim.html. Measure around the chimney. Use one of these chimney antenna mounts. ronard (2212) , ronard (2218) , ronard (2224).
http://www.ronard.com.
Buy the ronard antenna mounts at solidsignal by typing.
ronard (911).
ronard (4560).
In the solidsignal search box or buy from ronard.
http://www.solidsignal.com.
http://www.amazon.com.
http://www.channelmasterstore.com.
For 1 Tv connected with the CM4228HD antenna use No splitter.
No antenna system amplifier.
As always , trees and tree leaves , plants and plant leaves , have a negative effect on Broadcast Tv reception , multi-path/reflecting , absorbing , blocking , Broadcast Tv reception and so do buildings including your own roof and house and other obstructions.
The Best Practice is to install a Tv antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own roof and house.
_____________
The Tv/s Must Channel Scan for the , OTA=Over The Air , Digital Broadcast Tv stations/channels , often named the , 'Air Channels' or 'Antenna Channels' in the Tv Setup Menu because the Tv transmissions travel through the Air from the transmitting antenna to the receiving antenna.
Some Digital Tv's will Automatic channel scan for cable tv channels.
Go into the Tv Setup Menu and select , 'Air Channels' ~ 'Antenna Channels'.
Scan for channels.
Last edited by teleview; 20-Jun-2013 at 5:21 AM. Reason: Clarify information and typos.
