Old 12-Jun-2013, 7:51 PM   #2
Put the indoor Terk HDTVa antenna with the 2 extendable reception rods in a , south west / west , facing window.
The 2 extendable reception rods are for reception of the REAL VHF channels 2 thru 13.
Also as always , indoor antennas have -->Limited Reception Capabilities<--.
__________________________________________________________________
Have you done any thing or provided any information that - is/was - suggested/recommended - in the original thread??
http://forum.tvfool.com/showthread.php?t=13179.
Will you install a antenna outside Above the Peak of the Roof in such a manner that the roof and house are not blocking reception the directions of , south west , west , north west??
Also , As Always , trees and tree leaves , plants and plant leaves , have a negative effect on Broadcast Tv reception with a Tv antenna and so do buildings including your own , roof , attic , house and inside of house and other obstructions.
It is Best Practice to install a Broadcast Tv receiving antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own roof and house.
Last edited by teleview; 15-Jun-2013 at 1:05 PM. Reason: Clarify information and typos.
