Old 12-Jun-2013, 4:48 PM   #1
pigskins
Help with Terk HDTVa pointing/reception
http://www.tvfool.com/?option=com_wr...c08df35337165a
Based on map I am pointing the antenna to the southwest but not sure how to use a compass to get it more precise. At this point everything except ch 13 WHAM is coming in. In order to get that channel I have to extend the dipoles fully in a V-shape. If I lower them one segment I lose reception.
What is it about that channel that requires them, and for them to be fully extended?
I used a height of 12 feet because right now the antenna is sitting on a little end table next to the TV which is on a shelf. The antenna won't fit on the shelf, the poles are too long and hit the ceiling!
Thank you!
pigskins is offline   Reply With Quote
