Old 11-Jun-2013, 1:58 PM   #2
tvlurker
Address input BROKEN
There seems to be a problem with using any address, Canadian or American, for both the Online Maps and TV Signal Locator features.
What I do to work around it is to just click on Coordinates, and then provide an approximate lat/long which I then reposition on the map as required. For Ontario, I use lat 45 long -78.
Can someone look into to fixing this?
Here is the error from the TV Signal Locator :
ERROR: Geocoding service failure (code = 3). Please try again or use coordinates instead.
ERROR: The address could not be resolved. Please check the address or try entering coordinates instead.
ERROR: Longitude is out of range. Please check your location and try again.
Errors from Online Maps:
tvlurker is offline   Reply With Quote
