Old 10-Jun-2013, 6:46 PM   #6
The HD Blade antenna and other Flat antennas and other types of small indoor antennas.
The implied claims of having 'Super fantastic reception power' are misleading.
The Truth --> Small indoor type antennas , by the very nature of the act , will have limited reception.
________________________
The tvfool reports with correct address and antenna heights of 25 and 40 feet are very close to the same reception situation as the first tvfool report.
mtownsend recommendations of antennas will work Ok.
If you will like to receive the Local Tv stations in the Green and Yellow reception zones to the , north west , and east.
And also reach out for the Weaker Signal Strength Local Tv stations/channels in the Red reception zone.
WTSF-DT UHF channel 44 Daystar.
W30DG-D UHF channel 30 HSN.
Above the the Peak of the Roof in such a manner that reception is not blocked by the roof and house in the directions of , west , north west , east.
Install a Channel Master CM4228HD UHF/VHF antenna aimed at about 274 degree magnetic compass direction.
For 1 Tv connected use No splitter. No antenna system amplifier.
For 2 Tv's connected use a simple common 2 way splitter. No antenna amplifier.
http://www.solidsignal.com.
http://www.amazon.com.
http://www.ronard.com/909911.html. Use the 5 foot tripod antenna mount.
http://www.ronard.com/34424560.html. Use the #4560 eave antenna mount.
http://www.ronard.com/ychim.html. For strap length , measure around the chimney.
http://www.ronard.com.
Buy the ronard antenna mounts at solidsignal by typing.
ronard (911)
ronard (4560)
ronard (2212) , ronard (2218) , ronard (2224)
In the solidsignal search box or buy from ronard.
Last edited by teleview; 13-Jun-2013 at 7:51 AM. Reason: Clarify information and typos.
