Old 10-Jun-2013, 6:03 AM   #2
A Simple reception situation.
Many USA and Canada Digital Broadcast Tv stations/channels will be received.
The best place to install a AntennasDirect , ClearStream 2 Complete Uhf/Vhf antenna is Out on the wall of the balcony that is Away From The Building so the CS2 Complete antenna can receive more signal that is not disrupted by the building , at the front and back of the antenna.
http://www.antennasdirect.com/store/...VHF-Combo.html.
Aim the CS2 Complete antenna at about 170 degree magnetic compass direction.
Here is how to aim antenna , http://www.kyes.com/antenna/pointing/pointing.html.
_______________
A antenna system amplifier is not required.
_______________
_______________
http://www.saveandreplay.com.
http://www.trentondistributors.com.
http://www.antennasdirect.com.
http://www.amazon.ca.
http://www.solidsignal.com.
http://www.amazon.com.
________________
The Tv Must Channel Scan for the , OTA=Over The Air , Digital Broadcast Tv stations/channels , often named the 'Air Channels' or 'Antenna Channels' in the Tv Setup Menu because the Tv transmissions travel through the Air from the transmitting antenna to the receiving antenna.
Some Digital Tv's will Automatic channel scan for cable tv channels.
Go into the Tv Setup Menu and select , 'Air Channels' ~ 'Antenna Channels'.
Scan for channels.
