Old 10-Jun-2013, 1:55 AM   #4
Recommend Do Not use a antenna rotator , antenna rotation Is Not Channel Surfing Friendly , must wait for antenna to rotate , And Will Be Domestic Situations About The Direction The Antenna Is Aimed.
Go for the Many Digital Tv stations/channels the Atlanta area.
Aim the HD7698P antenna at about 356 degree magnetic compass direction as recommended.
Most Digital Tv's and Tuner boxes have a signal strength meter and some also have a signal quality meter.
The antenna aim direction can be adjusted for best reception of the Atlanta area Tv stations.
_____________________
Walmart has the simple RCA DTA800B1 converter box. http://www.walmart.com.
Here are boxes that do a lot more.
http://www.epvision.com.
http://www.channelmasterstore.com.
Last edited by teleview; 10-Jun-2013 at 9:54 PM. Reason: Clarify information and typos.
