The provided tvfool report says , Address was only resolved to the block level.
Hurricane WV area is a very rough terrain area with lots of gullies and hills and mountains.
And the provided tvfool report has no antenna height above ground entered in the report so it is the default 10 feet antenna height.
Not good.
_________________
Please make and post 2 tvfool reports with correct and accurate addresses.
One report 25 feet antenna height above ground.
Second report 40 feet antenna height above ground.
________
If accurate address function does not work , then go to the tvfool home page , click on , >>Start MAPS<< , move the pointer to your exact location , enter in antenna height , click on , Make Radar Map.
Reason: Clarify information and typos.
