Old 7-Jun-2013, 8:47 AM   #2
Looks like too many extra steps to find location and antenna height above ground.
It is better to go to the tvfool home page , click on >>Start MAPS<< , move the pointer to your location and enter a antenna height above ground , if you can install the antenna 50 feet above ground , then Ok.
Please make 2 tvfool reports , 25 feet and 50 feet above ground.
Click on the Make Radar Map button.
Do not delete the tvfool report with extra steps.
_____________________________________________________________
If the 'extra steps' location is correct and antenna height above ground is correct.
Then to receive.
WCDC-DT REAL UHF Digital channel 36.1-2 , virtual number (19.1-2) ABC and LWN Live Well Network.
W38DL-D REAL UHF Digital channel 38.1-2 , virtual number (12.1-2) a repeater for WNYT , NBC and Me-Tv.
WRGB ,REAL VHF low band Digital channel 6.1-2 , virtual number (6.1-2) CBS and This Tv.
WXXA-TV , REAL VHF high band Digital channel 7.1-2 , virtual number (23.1-2) FOX and The Country NetWork.
WNYT REAL VHF high band Digital channel 12.1-2 , virtual number (12.1-2) NBC and Me-Tv.
WNYA-DT REAL VHF high band Digital channel 13.1-2 , virtual number (51.1-2) MyNetwork and Antenna Tv.
Install a Winegard HD7084P All channel antenna above the the Peak of the Roof in such a manner that the roof and house are not blocking reception to the west south west.
Aim the HD7084P antenna at about 271 degree magnetic compass direction.
http://www.ronard.com/909911.html. Use the 5 foot tripod antenna mount.
http://www.ronard.com/34424560.html. Use the #4560 eave antenna mount.
http://www.ronard.com.
Buy the ronard antenna mounts at solidsignal by typing the word ronard in the solidsignal search box or buy from ronard.
Here are some places to buy antennas and etc.
http://www.solidsignal.com.
http://www.amazon.com.
Install a Winegard HDP-269 preamp.
Buy the HFS splitters at , http://www.solidsignal.com or http://www.hollandelectronics.com.
The satellite system coaxes and the coaxes that are on or in the house can be used for the antenna system.
Disconnect and Remove passive and active satellite system componets such as , multi-switches , multi-plexers , diplexers , combiners , splitters , amplifiers , power injectors , power supplies and etc. .
Last edited by teleview; 7-Jun-2013 at 10:41 PM. Reason: Clarify information and typos.
