Old 6-Jun-2013, 12:59 PM   #1
raydogg34
New OTA Setup Questions
Hello everyone first post here, just looking for some advice and guidance. I have attached my tvfool report to help get a sense of equipment to purchase for my location. There is currently no antenna equipment at the house, using RoadRunner for internet that we will keep. Plan to install new RG6 quad for new antenna installation. Here is my tvfool signal analysis I have also attached the image, just in case the link does not work.
http://www.tvfool.com/?option=com_wr...1ddaaaaa5d73ca
I know it may be a long shot to get a lot of channels due to our distance from major cities. I am primarily concerned with receiving WEWS, WKYC, WJW, and WOIO if possible but the more the merrier. Not sure if an attic mount would work for our location, it is split level ranch home with composite shingle roof. From the back of the house roughly points in the direction of these transmitters with a clear line of sight if roof mounted, and opens into a field. I plan on purchasing a HD Home run, just unsure on other equipment and really the best solution for antenna and location. I would like to provide signal to 3 televisions, 2 large lcds, and a smaller lcd tv. Any help would be greatly appreciated as far as amps, antenna, splitter, and any other equipment you would recommend. Thanks in advance.
raydogg34 is offline   Reply With Quote
