A Winegard 7694 or Antennacraft HBU-33 mounted outside should provide reliable reception at your location. Something smaller like an RCA ANT-751 or Antennas Direct C2-V may do the trick, but I would personally go a little larger. This will lessen the chance of signal interruptions from multipath reflections created by low flying aircraft.
I live directly underneath the flight path of Washington Dulles airport (3 miles from runway) & reception is good even with an attic mounted antenna. Occasional signal interruptions from low incoming aircraft occur rarely on certain channels, but not a deal breaker on my conventional TV's. The USB tuner I use on my computer suffers a bit more interruption, but I rarely use it.
