Old 5-Jun-2013, 12:10 AM   #2
The Tv transmission and reception that was the Analog Tv past is -->Now The Past<-- and -->No Longer Applies.
____________________________________________________
You will receive , Many , many , many , many , many , many , many , Digital Tv stations/channels at your location.
The current Tv channels that are transmitted and received , USA , Canada , Mexico , are.
UHF band channels 14 thru 51.
Your location has receivable Tv stations/channels , All 3 channel bands.
Recommend install a -AntennaCraft HD850 All channel antenna- Above The Peak of the Roof on the chimney in such a manner that reception is not blocked buy the roof and house in the directions of , east , south east , south west.
Aim the HD850 All channel antenna at 143 degree magnetic compass direction.
Here is a chimney antenna mount , http://www.ronard.com/ychim.html. Measure around the chimney for strap length.
http://www.ronard.com.
Buy the ronard antenna mount at solidsignal by typing the word ronard in the solidsignal search box or buy from ronard.
For 1 Tv connected use No splitter. No antenna system amplifier.
For 2 Tv's connected use a simple common 2 way splitter. No antenna system amplifier.
http://www.solidsignal.com.
http://www.amazon.com.
For outside coax use the coax that has the Compression type connectors on the ends of the coax , not the old crimp type connectors.
To keep weather/water out of outside connections and coax and the matching transformer that connects the coax to the antenna , wrap all connections and coax and the matching transformer with , http://www.coaxseal.com.
Do not use 'weather boots' , the boots do not keep water out , the boots take in water and hold the water inside the boots causing bad connections.
Here are alternatives to using a computer to receive and record Digital Broadcast Tv.
1.
Digital Tv Tuner/Recorders. http://www.epvision.com.
2.
http://www.channelmasterstore.com.
3.
A Digital Tv.
As always , trees and tree leaves , plants and plant leaves , have a negative effect on , Broadcast Tv reception with a Tv antenna , multi-path/reflections , absorbing , blocking , Tv reception and so do buildings including your own roof and house and other obstructions.
It is best to install the HD850 All channel antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own roof and house.
The Tuners Must Channel Scan for the Digital Broadcast Tv stations/channels , often name the 'Air Channels' or 'Antenna Channels' in the Tuner/Tv Setup Menu because the Tv transmissions travel through the Air from the transmitting antenna to the receiving antenna.
Some Digital tuners will Automatic channel scan for cable tv channels.
Do Not channel scan for cable tv channels.
Go into the Setup Menu and select 'Air Channels' ~ 'Antenna Channels'.
Scan for channels.
Last edited by teleview; 5-Jun-2013 at 6:16 AM. Reason: Clarify information and typos.
