Old 31-May-2013, 1:20 AM   #2
Attics and the inside of buildings Are Not a reception friendly environment and Never Will Be a reception friendly environment.
Multi-path/reflections Tv signals bouncing all around , absorbing , blocking , Tv reception.
Looking at the tvfool radar plot and channel list for the Current Plus Pending Applications Included Digital Channels List , the Digital Tv stations/channels in the Green/Yellow reception zone , down the channel list to and including , WJWJ-DT REAL UHF Digital channel 44 , virtual number (16.1) PBS channels should be received.
_____________________________________________________________
Question:
Can reliable reception happen in the attic and inside of buildings??
Answer:
Yes reliable reception can happen in the attic and inside of buildings.
Also the Truth:
However that does not mean that attics and the inside of buildings are a reception friendly environment.
Yes start with a antenna installed in the attic.
Aim the antenna at about 100 degree magnetic compass direction.
Here is how to aim antennas , http://www.kyes.com/antenna/pointing/pointing.html
Install a Antennas Direct Clear Stream 2 Complete Uhf/Vhf antenna.
http://www.antennasdirect.com/store/...VHF-Combo.html.
If there are reception situations/problems that are not resolvable buy adjusting the antenna aim and location of the antenna in the attic.
Move the CS2 Complete antenna to Above the Peak Of The Roof in such a manner that reception is not blocked by the roof and house in the directions of , east , south east , south west.
Above the roof , aim the CS2 Complete antenna at about 100 degree magnetic compass direction.
http://www.solidsignal.com.
http://www.amazon.com.
http://www.antennasdirect.com.
The reception signal strength of the local Tv stations/channels are strong at your location.
___________
A antenna system amplifier is not required.
___________
A antenna rotator is not required.
___________
For 4 Tv's connected use a simple common 4 way splitter.
The Best Practice and Correct Way to connect the Tv's is to have a coax go out to each Tv location from each splitter output.
Recommend do not daisy chain splitters.
Chaining splitters one after the other , a splitter connected to an other splitter , connected to an other splitter , connected to an other splitter , connected to an other splitter , connected to an other splitter , connected to another splitter , is a good way to have Little Useable Signal in the chain and at the end of the chain of splitters.
Installing amplifiers in the chain of splitters to increase signal strength in the chain is a good way to cause problems with reception/distribution , not solve problems with reception/distribution.
If there is any active cable service , be it , cable tv , cable internet , cable phone service , the antenna Can Not be connected to any type or kind of active cable service.
If there is active cable service the active cable service Must Be on Separate coax.
_______
Yes the coaxes that are in or on the house can be used for the antenna system , however active cable system and antenna system coaxes Can Not be connected together.
___________________
As always , trees and tree leaves , plants and plant leaves , have a negative effect , multi-path/reflections , absorbing , blocking , Tv reception and so do buildings , including your own roof and house and other obstructions.
The best practice is to install the CS2 Complete antenna at a location that has the least amount to no amount of obstructions of any type or kind the directions of reception including your own roof and house.
The Tv's Must Channel Scan for the , OTA=Over The Air , Digital Broadcast Tv stations channels , often named the 'Air Channels' or 'Antenna Channels' in the Tv Setup Menu because the Tv transmissions travel through the Air from the transmitting antenna to the receiving antenna.
Scan for channels.
Last edited by teleview; 3-Jun-2013 at 3:18 PM. Reason: Clarify information and typos.
