Thread: Antenna Help
Old 28-May-2013, 8:08 PM   #4
A Simple reception situation.
For the reception of , Many , many , many , many , Digital Broadcast Tv stations/channels.
Above the Peak of the Roof in such a manner that reception is not blocked by the roof and house of the directions , north east , east , south east , install a Antennas Direct , ClearStream 2 Complete Uhf/Vhf antenna aimed at about 75 degree magnetic compass direction.
http://www.antennasdirect.com/store/...VHF-Combo.html.
As always , the starting antenna aim direction is the -->starting antenna aim direction.
The antenna aim direction can be adjusted for best reception.
Most Digital Tv's have a Signal Strength Meter and some Digital Tv's have a Signal Quality Meter.
___________________________________________________
A antenna system amplifier is not required.
For 3 Tv's connected use a simple common 3 way splitter.
For 4 Tv's connected use a simple common 4 way splitter.
To keep weather/water out of outside connections , For outside coax and connections use the coax that has the Compression type connectors on the ends of the coax , not the old crimp type connectors.
To make double sure that weather/water does not get into outside connections , wrap connections and coax with http://www.coaxseal.com.
_______________________________________________________
http://www.saveandreplay.com.
http://www.trentondistributors.com.
http://www.antennasdirect.com.
http://www.amazon.ca.
http://www.solidsignal.com.
http://www.amazon.com.
___________________________________________________________
As always , trees and tree leaves , plants and plant leaves , have a negative effect on Tv reception , multi-path/reflections , absorbing , blocking , Tv reception , and so buildings including your own roof and house and other obstructions.
The Best Practice is to install the CS2 Complete antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own roof and house.
The Tv/s Must Channel Scan for the , OTA=Over The Air , Digital Broadcast Tv stations/channels , often named the 'Air Channels' or 'Antenna Channels' in the Tv Setup Menu because the Tv transmissions travel through the Air from the transmitting antenna to the receiving antenna.
Some Digital Tv's will Automatic channel scan for cable tv channels.
Go into the Tv Setup Menu and select 'Air Channels' ~ 'Antenna Channels'.
Scan for channels.
