Old 25-May-2013, 5:54 AM   #6
To reach out for the long distance reception of , NBC , CBS , PBS , FOX , MyNetwork , The CW , LWN Live Well Network , This Tv , Me-Tv , Antenna Tv , Cozi Tv , Multi-World Networks , Independent Networks , Mundo Fox , Univision , to the South East.
Install above the Peak of the Roof in such a manner that reception is not blocked by the roof and house , a Winegard HD7698P antenna aimed at about 127 degree magnetic compass direction.
_____________________________________________
Here are some Strong and Sturdy antenna mounts.
http://www.ronard.com/909911.html. Use the 5 foot tripod antenna mount.
http://www.ronard.com/34424560.html. Use the #4560 eave antenna mount.
http://www.ronard.com.
http://www.solidsignal.com.
http://www.amazon.com.
Install a Winegard AP8700 preamp.
Buy the HFS splitters at , http://www.solidsignal.com , or , http://www.hollandelectronics.com.
3 Local Digital Tv stations/channels will most likely be received also.
WWPX , ION.
W07DN , PBS.
WVPY , PBS.
And possibly WHAG , NBC.
_________
The ABC Tv station WJLA-Tv channel 07 , ABC will not be received. The signal is too weak.
The strong signal strength , local W07DN-D channel 07 PBS will be received.
__________
The Local ABC Tv station WHSV , ABC will most likely not be received. The problem is your location , terrain blockage = hills and mountains
______________
Terrain blockage of All Tv Stations except 1 - W07DN-D channel 07 PBS.
Is the number 1 issue/problem at your location.
I reverse engineered to a location close to your location and entered in higher antenna heights to see if higher antenna heights would help reception.
Not enough to go any higher then 25 feet.
Reception does improve , a little , by having the antenna lower then 25 feet.
About 10 to 15 feet above ground is Ok.
However installing the antenna at about 10 to 15 feet might be to low , because if there are trees blocking reception at the lower antenna height.
As always, trees and tree leaves , plants and plant leaves , have a negative effect on reception , multi-path/reflections , absorbing , blocking , reception and so do buildings and other obstructions including your own roof and house.
The best practice is to install the antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own roof and house.
At your location that is , south east , north east , south-south west.
As a Test of reception of WHSV , ABC , aim the HD7698P antenna at about 192 degree magnetic compass direction , and scan for channels.
The Tv's Must Scan for the OTA=Over The Air , Digital Broadcast Tv stations/channels , often named the 'Air Channels' or 'Antenna Channels' in the Tv Setup Menu because the Tv transmissions travel through the Air from the transmitting antenna to the receiving antenna.
Go into the Tv Setup Menu and select 'Air Channels ~ 'Antenna Channels'.
Scan for channels.
