Old 22-May-2013, 2:17 PM   #18
Not a surprise for me.
______________________
The amplifier will most likely provide reliable reception.
You can also do the following.
Most Digital Tv's have a Signal Strength Meter and some Digital Tv's have a Signal Quality Meter.
If the Tv has a Signal Quality meter , Signal Quality -> Is Important For Reliable Reception.
With some one watching the Tv for the best reception , raise and lower the antenna and adjust the aim direction of the antenna to find reliable reception.
To keep water out of outside connections , use coax that has the Compression type connectors on the ends of the coax , not the old crimp type connectors.
To make double sure that water does not get into outside connections , wrap connections and coax with , http://www.coaxseal.com.
Last edited by teleview; 23-May-2013 at 8:11 AM. Reason: Clarify information and typos.
