Old 20-May-2013, 8:14 PM   #1
nico08
Need Antenna Advice- Old Bridge, New Jersey
Hi:
I was wondering if you could give me some advice. I have included the link to my report below.
I made my own antenna a couple of years ago but I only got like one or two channels.
I want to connect antenna to two HD TVs. I would prefer an attic antenna, but I would get a roof antenna if I could get a lot more channels.
There are no mounting restrictions. I live in a ranch house with 3 large trees in front yard. The roof is made of asphalt shingles.
I cant stand in attic, it is about 3 feet high at tallest point, but there is room for an antenna. There is no chimney. I think there is an old mounting pole on the roof from an old antenna from years ago. The antenna system does not need to be incorporated into a DirecTV or Dish system.
Optimum/Cablevision offers a VERY basic cable tv plan for 10-12 dollars a month. Should I go with that instead of paying for and relying on an antenna?
Do I need any of the following: mast; attentuator; amplifier; multiswitch; diplexer; a motor to rotate the antenna?
What kind of cable should I use? Do I need to ground the antenna?
Someone recommended the Wineguard HD8200U but it costs $117 and that seems expensive. Is there anything just as good at a lower price?
Thank you for your advice.
http://www.tvfool.com/?option=com_wr...1dda6b0cdcbc36
nico08 is offline   Reply With Quote
