Thread: Free Beer
Old 16-May-2013, 8:09 PM   #3
Here is a 1 antenna recommendation for receiving the Distant Charlotte-Gastonia area Digital Tv stations/channels to the , south west.
And some Local Digital Tv stations/channels to the , north west , north east , south east.
Above the peak of the roof in such a manner that the peak of the roof and house are not blocking reception to the , south west , north west , north east , south east.
Install a Winegard HD9095P UHF antenna aimed at about , 235 degree magnetic compass direction.
____________
Install a Winegard HDP-269 preamp.
____________
For 4 Tv's connected use a , HFS-4D , 4 way splitter.
Buy the HFS splitters at , http://www.solidsignal.com , or , http://www.hollandelectronics.com.
____________
http://www.ronard.com/909911.html. Use the 5 foot tripod antenna mount.
http://www.ronard.com/34424560.html. Use the #4560 eave antenna mount.
http://www.ronard.com.
_______________
http://www.solidsignal.com.
http://www.amazon.com.
_________________
As always , trees and tree leaves , plants and plant leaves , have a negative effect , on Digital Broadcast Tv Reception and so does your own roof and house , other buildings and other obstructions.
It is best to install the HD9095P antenna at a location that has the least amount to no amount of obstructions of any type or kind in the directions of reception including your own roof and house.
______________________
The Tv's Must Channel Scan for the , OTA=Over The Air , Digital Broadcast Tv stations/channels , often named the 'Air Channels' or 'Antenna Channels' in the Tv Setup Menu because the Tv transmissions travel through the Air from the transmitting antenna to the receiving antenna.
Go into the Tv Setup Menu and select , 'Air Channels' , 'Antenna Channels'.
Scan for channels.
Last edited by teleview; 24-Jul-2013 at 6:15 PM. Reason: Clarify information and typos.
