Old 14-May-2013, 7:08 PM   #3
The.
CM5020.
CM5018.
CM5016.
CM3026.
CM3023.
CM3022.
Showed up on the Channel Master web site awhile back.
http://www.channelmasterstore.com.
NOT NEW.
A standard antenna design that has been around for a long time.
The < shaped UHF reflectors are very small and will not reflect much signal to the UHF reception element.
A small number of VHF reception elements means that precise spacing and element lengths is required to get improved reception , this small number and precise spacing and element lengths means there is no 'elbow room' for reception if the antenna elements are bent or broken.
The antennas are over priced for what you get.
________________________
Antennas do not reject adjacent channels.
As an example but not the only example.
Channel 30 is the main channel.
Channels 27 , 28 , 29 and 31 , 32 , 33 , are adjacent to 30.
----------------->Antennas Receive Adjacent Channels.<--------------------
__________________________________________________________
Last edited by teleview; 15-May-2013 at 2:40 PM. Reason: Clarify information and typos.
