All of your calculated NM(dB) numbers are above the Plus +10.0 NM(dB) reference point number.
The Plus +10.0 NM(dB) provides some elbow room for signal variances.
The stronger signal strengths provide more elbow room.
The FCC reference point number is 0 NM(dB) for LOS Line Of Sight transmission and reception.
And reliable reception does happen with negative -NM(dB) numbers.
Reason: Clarify information and typos.
