Old 12-May-2013, 10:30 PM   #3
monkeedu
Thanks for the advice. Based on that, would you recommend the following?
Antenna - http://www.antennasdirect.com/store/...V-Antenna.html
DA - http://www.antennasdirect.com/store/...amplifier.html
Coaxial Ground - http://www.amazon.com/1GHz-Single-F-.../dp/B001I5610E
What gauge grounding wire should I use for the cable vs the mast? Also, can I ground both to the same grounding rod as an existing cable internet ground?
monkeedu is offline   Reply With Quote
