Old 26-Oct-2010, 3:52 PM   #1
ravenjim
Help With Reception
Hello All,
I currently have an older vhf/uhf Channel Master long fringe antenna installed in my attick. The channel I really need to pick up is wjz-tv 13 out of Baltimore. Channels 2,11,45,54 all come in with no signal loss. Channel 13 the one I need keeps losing its signal. There is no amplifier used here and I need to keep the antenna in the attick and not on the roof.
Is there a better antenna you can recommend that will bring in this station which is only 55 miles away. I've tried tilting the angle and moving it to different locations with no luck. There are no trees or buildings for at least 4 miles and then a small ridge to get over.
Thanks in Advance, Jim
http://www.tvfool.com/?option=com_wr...cef3f55aa1cb9b
ravenjim is offline   Reply With Quote
