Yes , minus -9.0 ~ -10.0 NM(dB) and ~ minus -100 Pwr(dBm) are target figures/practical limits for reliable reception.
Some reception locations have reliable reception down to ~ minus -15 NM(dB).
____________________________
This fried tuner misinformation keeps popping up on the internet mis/information web sites.
The Tv tuner - Will Not be fried - by strong local Tv transmissions.
______
When a tuner or amplifier receives more/stronger signal then the design parameters , then the circuit can not process the signal/s correctly.
The result is , some or all frequencies , Tv channels , are distorted.
___________________
A antenna connected to a Tv and receiving Strong local Tv transmissions , the Tv tuner -> Will Not Be <- fried.
A antenna system amplifier -> Will Not Be <- fried.
__
By both high signal and low signal strengths.
The signals can become distorted.
The result is bad reception.
The only way to find out if those low signal strength USA digital Tv stations are reliably received.
Is install a antenna without a amplifier and see what happens.
And install a amplifier and see what happens.
The correct way to test for reception of the low signal strength Tv stations is to connect only 1 Tv for the test.
No splitters , splitters reduce signal strength each time a split takes place.
The correct way to test for reception is the simplest way.
Do not connect 50 tv's and a big honk'n amplifier and then wonder whats wrong.
