Old 9-May-2013, 9:16 AM   #6
Guru
I suspect the oak trees will be a constant source of signal quality problems. Getting over or around those trees would be the single most productive improvement in your situation.
You have some strong local signals so you'll want a preamp that can tolerate high input levels. The Winegard HDP-269 and Antennacraft 10G201 & 10G221 come to mind.
FWIW: Historically, I don't recommend the HD-Stacker, not because it's good bad or indifferent... But because it's an unknown quantity. Denny only offers anecdotal comparisons to generally dissimilar antennas. I prefer to recommend antennas that have published performance specifications. Having said that, my guess is that the 'Stacker' performs somewhat like a Winegard HD7694P. If I was trying for the distant group of signal to the east, I would go big... A Winegard HD7698P or large separate UHF and H-VHF antennas. I would also be considering a tower that would get me above all obstructions in the neighborhood.
http://forum.tvfool.com/showthread.php?t=13090
Thanks for the advice and thanks for not completely dismissing my antenna choice. I was a little worried about those trees but at much as I would love to have the KC stations, they are not so important to me as to spend a bunch of extra money on a tower and rewiring my home with an electrician. If I can't make it work with my existing wiring for the KC channels then I can live with only getting the Topeka stations.
I'll take a closer look at your pre amp suggestions. Thanks
Guru is offline   Reply With Quote
