Old 9-May-2013, 1:35 AM   #5
A Simple reception situation.
For reception of the Local Digital Tv stations/channels to the , south-south west and east ,
With 1 Antenna.
Install a Winegard HD7696P antenna , about 20~25 feet above ground in such a manner that the roof and house are not blocking reception to the , south-south west and east.
Aim the HD7696P antenna at about 210 degreee magnetic compass direction.
A antenna rotator is not required.
A preamplifier or distribution amplifier is not required.
___________________________________________________________
These Local Digital Broadcast Tv stations/channels will be received.
Tuff Tv , PBS channels , FOX , Bounce Tv , ABC , Telemundo , LWN Live Well Network , CBS , The CW , NBC , MyNetwork , Religion.
K20HO Real UHF Digital channel 20 , virtual number (20.1) a repeater transmitter for KXCO-LP , Tuff Tv.
K36AB-D Real UHF Digital channel 36 , a repeater transmitter for KETA - OETA , PBS channels.
K25IC Real UHF Digital channel 25 , Construction Permit.
KJTL-DT Real UHF Digital channel 15 , virtual number (18.1-2) FOX and Bounce Tv.
K38GL-D Real UHF Digital channel 38 , Religion.
KSWO-DT Real VHF Digital channel 11 , virtual number (7.1-2-3) ABC and Telemundo and LWN Live Well Network.
K43LK-D Real UHF Digital channel 43 , virtual number (43.1) Religion.
K18IZ-D Real UHF Digital channel 18 , a repeater transmitter for KETA - OETA , PBS channels.
KUAZ-TV Real UHF Digital channel 22 , virtual number (6.1-2) CBS and The CW.
KFDX-DT Real UHF Digital channel 28 , virtual number (3.1-2) NBC and MyNetwork.
Here are some common above the roof antenna mounts.
http://www.ronard.com/909911.html. Use the 5 foot tripod antenna mount.
http://www.ronard.com/34424560.html. Use the #4560 eave antenna mount.
http://www.ronard.com.
___________________
http://www.solidsignal.com.
http://www.amazon.com.
As always , trees and tree leaves , plants and plant leaves , produce a negative reception situation , absorbing , multi-path/reflecting , blocking , Digital Broadcast Tv reception and so do building and other obstructions including your own roof and house.
The best practice is to install the HD7696P antenna at a location that has the least amount to no amount of any type or kind of obstructions in the directions of reception.
At your location the local Tv stations are to the , south-south west and east.
The Tv/s Must Channel Scan for the OTA=Over The Air , Digital Broadcast Tv stations/channels , often named the , 'Air Channels' or 'Antenna Channels' in the Tv Setup Menu because the Tv transmissions travel through the Air from the transmitting antenna to the receiving antenna.
Go into the Tv Setup Menu and select , 'Air Channels' ~ 'Antenna Channels'.
Scan for channels.
Last edited by teleview; 10-May-2013 at 5:25 AM. Reason: Clarify information and typos.
