Teleview,
Thank you for the link to my previous inquiry. This is a new setup that I am still trying to work the kinks out of. By posting that link, are you implying that I am running into to same issue I had last time?
GroundUrMast,
As always, thank you for your help and actually making suggestions to work through the issue. I will try your suggestion. I know from previous trials and errors that all my coaxial connections are good. But I will use the direct line from the antenna to the basement and hook up a tv before the signal is split to see what happens. Should I just disconnect the preamp completely when I do this?
Does this idea that I have to catch signals at my back end make any sense? It seems to be working right now with some of my further stations to the west but not all of them.
I did look into the Jointenna as that seems to be my best option. The A/B option is not feasible for me because I have no way to rerun cable from my basement to the tv's. (Whole house is spray foamed, which makes it extremely difficult.) I would even consider buying another small antenna and a jointenna to get the stations that i want to the west. Just not sure what to get at this point.
I looked at the tinlee site and was kinda confused on what component I would actually need.
I will get back to you after I try the coaxial test you suggested.
Thanks Again!
