You might try an FM filter between the antenna and the pre-amp.
Other than that, adding the C5 or a similar high-VHF antenna would be the logical next step.
Because of the manner in which VHF signal's diffraction is different from UHF signals, the VHF antenna may need to be further away from the UHF antenna.
