Old 6-May-2013, 8:54 PM   #2
For your reception situation , 1 antenna will do it all.
A Channel Master CM4228HD UHF/VHF antenna will receive the local Canada Digital Tv stations/channels.
The local channels are -->Very Strong Signal Strength<-- and the CM4228HD UHF/VHF antenna will receive the local Digital Tv stations/channels at the front and back of the CM4228HD UHF/VHF antenna because the local Digital Tv stations/channels are Very Strong Signal Strength.
No preamplifier or distribution amplifier is required for reception of the local Digital Tv stations channels.
Aim the CM4228HD UHF/VHF antenna at about 150 degree magnetic compass direction.
A Tv antenna rotator is not required.
________________________________________
For 3 Tv's connected use a simple common 3 way splitter.
______________________________________________________________
For reception of some USA Digital Tv stations/channels.
The Same<->Channel Master CM4228HD aimed the same direction at about 150 magnetic compass direction.
150 degree is a in between aim direction for reception of the USA Digital Tv station/channels.
As always , the starting antenna aim direction is the --> starting antenna aim direction.
The antenna aim direction can be adjusted to provide the best reception.
Most Digital Tv's have a signal strength meter and some Digital Tv's also have a signal quality meter.
WNPI-DT Real UHF Digital channel 23 , PBS channels. Will most likely be reliably received.
http://en.wikipedia.org/wiki/WPBS-DT.
The next 2 Digital Tv stations/channels , may or may not be received reliably.
WCFE-DT Real UHF Digital channel 38 , PBS channels.
http://en.wikipedia.org/wiki/WCFE-TV.
WNYF-LD Real UHF Digital channel 18 , FOX and digital sub channel - WWNY , CBS.
http://en.wikipedia.org/wiki/WNYF-CD.
The Canada Digital Tv stations/channels are Very Strong Signal Strength , so a amplifier that has high resistance to being overloaded is required for reception of the USA Digital Tv stations/channels that are Very Weak Signal Strength.
Install a Winegard 'Boost' amplifier , LNA-100.
The LNA-100 is not weather/water resistant , so the LNA-100 is installed at a location that is out of the weather/water.
The LNA-100 is installed before the input side of the splitter.
The best practice is to install the amplifier closer to the antenna , to get the most and strongest signal from the antenna before any signal strength losses through long lengths of coax.
Reliable reception of the USA Digital Tv stations is the goal.
As examples , here are some common antenna mounts.
http://www.ronard.com/909911.html. Use the 5 foot tripod antenna mount. ronard (911)
http://www.ronard.com/34424560.html. Use the #4560 eave antenna mount.
Measure chimney. ronard (2212) , ronard (2218) , ronard (2224) .
http://www.ronard.com.
http://www.saveandreplay.com.
http://www.trentondistributors.com.
http://www.amazon.ca.
http://www.channelmasterstore.com.
http://www.amazon.com.
Last edited by teleview; 24-Jun-2013 at 3:10 PM. Reason: Clarify information and typos.
