As always , the claims of 150 mile reception are claims that are designed to separate you from your money.
____________________________________________________
The tvfool radar report and channel list you provided is not showing any antenna height above ground.
Please make and post a tvfool radar report and channel list with the antenna height at 25 feet above ground to see if signal strengths improve at the long distance reception of 80 plus miles.
_______________________________________________________________________________
Also with a about 25 foot antenna height , the local tv stations - weaker signal strength digital tv stations/channels , will likely improve in signal strength so reception can happen with 1 antenna.
Please make and post a tvfool radar plot and channel list with the antenna height 25 feet.
