My personal choice is to avoid a rotator if possible...
http://forum.tvfool.com/showthread.php?t=820
http://forum.tvfool.com/showthread.php?t=2882
http://forum.tvfool.com/showthread.php?t=8275
If you need or want a rotator, the Channel Master CM-9521A is probably the easiest to find at an affordable price. The NTE U-106 and matching TB-105 thrust bearing would be better in this case, as it would carry a heavy, long or wide antenna with far less chance of wind damage to the rotator housing.  http://www.3starinc.com/antenna_rotors.html
A premium option would be the Hy-Gain AR-40.  http://www.hy-gain.com/Product.php?productid=AR-40
