Old 26-Oct-2010, 3:21 AM   #5
Smith
Hi GroundUrMast,
Well, as far as radio goes, I would like to get WKMS, in Kentucky. I get it now, just not very clear as the signal fades in and out.
The FM fool signal shows that station to be 60 miles southeast of zip 62917.
Other than that, I thought it would be nice to get as many stations as possible. At the moment, I have two receivers that I thought I might run each to an antenna or splt the signal. They are in separate rooms.
The provision for the AM antenna on the receiver has two threaded posts that you would put eyelets or a open spade on and then tighten the finger nuts.
I was checking out the Sony XDR-F1HD Radio tuner, but I don't think I really need it. I probably just need an outdoor antenna. Or antennas, if it is better to just give these receivers each their own. Are these FM antennas inexpensive?
Smith is offline   Reply With Quote
