Ok. So I installed the winegard hd1080 on a short mast on the eave of my house. I get all the San Diego local network channels plus a bunch of channels from Tijuana. Oddly, I also get KTTV and KCOP from Los Angeles. I don't get CW but I am not too concerned about that. I guess it is on a third location in Tijuana.
My next question is do I need to ground the antenna? And if so, what is suggested? My antenna is mounted on my eave. All total, it is maybe 12 feet off the ground. While I was on the roof, I looked at my DirecTV dish and I am not sure it is grounded. There is a white wire running with the coax from the dish to the eave and then just coils in a circle, not attached to anything. I appreciate any suggestions on what should be done with respect to grounding. Thank you. Jason
